Results 1 to 11 of 11
    Liked: 433
    Default Rear Brake Rotor
    Hi. I am looking to see if anybody knows what rear brake rotor is used when you are running a MK8 with outboard discs. Thanks in advance for any available help.
    Graham
    Memphis, TN, USA
    Liked: 416
    That will depend on the application (i.e. upright, caliper choice, CV joints vs. U-joints, etc.)
    Charlie Warner
    fatto gatto racing
    Liked: 433
    The upright is same dimensions as a Lotus 61. So it has the U joint. Thanks.
    Graham
    Memphis, TN, USA
    Liked: 416
    What caliper spacing is needed? Thickness desired.
    Charlie Warner
    fatto gatto racing
    Liked: 433
    That is variable but probably prefer the hat face to rotor rear face 1.50 to 1.85”. The caliper (ld14) mount will be made.
    Graham
    Liked: 141
    What brand of car or is it a one off custom?
    Liked: 433
    It is on what started like as a Lotus 61 but was quite modified over the years. It has a MK9 in it which I am changing over to outboard discs rather than inboard. It will also be running donuts and U joints, not cvs. Thanks for all the help so far.
    Graham
    NW Colorado
    Liked: 30
    Default Axle
    Does it still have the Lotus stub axles...
    http://www.leechapmanracing.com/images/rear_axle.gif
    or something different???
    John Mihalich, Jr.
    Liked: 1879
    If custom disks need to be made, i do a lot of them.
    NW Colorado
    Liked: 30
    Default Standard Setup
    R.Pare,
    You have a standard setup for the Lotus 20/22/23/31/51/61 rear rotor? Aluminum hat with standard rotor (Coleman or?)???
    John Mihalich, Jr.
    lffr | hotmail | com
    Liked: 1879
    No data on that car, unfortunately. However, if you or someone can send me a sample, i can get it drawn up and in the database.
    Rotor/hat could be 1-piece, 2-piece solid bolted together, or 2-piece floating. Prices for any of those combos would run somewhere between $275 to maybe $300 each, depending on the design, material costs, and the number produced.
    The exception to that cost-wise might be if the rotors are inboard. My "standard' design for floating rotors is to have the drive lugs machined as part of the aluminium hat, but we had an issue a few years ago with that setup on a Crossle - the engine.gearbox vibrations wore the lugs VERY quickly. For an inboard setup, a safer version would be to machine up some steel T-shaped lugs that dog into the hat - the steel should last many times that of the aluminium version, and be repalceable if ever necessary. However, machining the steel lugs would add a fair amount to the machining costs, naturally.
