Results 1 to 16 of 16
    Massachusetts
    Default Citation Steering
    Have a 1990 Citation with the funky steering setup. Have the beam etc. but not the funky little arms that pivot off the lower beam. Anyone???
    Thanks!
    Senior Member Amon's Avatar
    Medina, Ohio
    Liked: 174
    Contact Steve Pastore at VSR and he can either make or sell you the smaller tie-rods. Do you have
    the Bell-cranks that are part of the beam and the tie-rods attach to them?
    Massachusetts
    Hi Mark,
    Thanks! Yes, I just found Steve's info in my pile and sent him a note. I have a replacement beam with the old steering box and Pittman but that's it. I guess I'll need to weld on the bell cranks from what I recall.
    Torrington CT
    Liked: 481
    Steve is super and you will need him for a lot of things, but you have the new owner of Citation cars in your backyard:
    (603) 897-5140
    https://revolutionformulacars.com/
    107 Christie Rd, New Boston, NH 03070
    KEVIN O'HEARN
    PS - Who was the previous owner of your car?
    ChrisZ
    Medina, Ohio
    Liked: 174
    Boothy,
    You don't weld on the bellcranks but rather the mounts for the bellcranks as the bellcranks are removeable, but the blocks for the bellcranks aren't without much work. You'll also want the bellcranks that are solid and not the cast bellcranks which should only be used in an emergency for short stints. As mentioned, Steve is a wealth of information and can make almost anything you need that can't be purchased from the person who bought Citation cars etc.... Good luck!
    Massachusetts
    Boothy,
    Thank you! That's what I'm thinking was the block for the bell cranks. Good info. I appreciate it.
    Massachusetts
    (603) 897-5140
    KEVIN O'HEARN
    ChrisZ
    Thanks! I was wondering about all this for a while. Chris Barry had this before me. Terrific guy.
    I have done a lot of those "funky" steering setups.
    My advise is that you find some one who really knows what they are doing when you add the mounting blocks to an axle beam. It is very easy to ruin the inner bearing. That bearing is under the mounting block where you have to do the welding. For that reason, you have to be extremely carful as the block is welded to the beam.
    Menominee, MI 49858
    Liked: 88
    (603) 897-5140
    KEVIN O'HEARN
    ChrisZ
    Kevin should have all the parts you need, probably on the shelf, and the ability to do the welding of the blocks to the beam.
    Larry Campbell
    Campbell Motorsport
    Liked: 304
    Good time to check and replace the inner beam bushings. I did it after welding the mounting blocks to the beam.
    North Brunswick, NJ
    ...and clean the grease out of the tubes... sends out quite a smoke signal when being welded if not!
  14. The following 2 users liked this post:
  15. #12
    Liked: 304
    Quote Originally Posted by wroche29 View Post
    I hot tanked mine.
  16. #13
    Burr Ridge, Illinois
    Liked: 301
    ...sends out quite a smoke signal when being welded....
    ...unless of course, you like that sort of thing...
    Glenn
    "I LOVE the smell of gear-lube in the morning..."
  17. #14
    Massachusetts
    Quote Originally Posted by Boothy View Post
    Thanks!!!
    I am taking my beam up to Kevin over the next few weeks. I figured it's just a pivot point so how bad can it be but I've learned to take the advice of those who know...
    Liked: 304
    Here is a drawing I made a few years ago for the steering arm base. It is just the simple part. It gets welded directly across the front to the beam. On the back side you need to add a strip of sheet material, 18g or so and weld the strip to the beam and the mount on the backside to make up the gap that occurs from the tube curvature.
    I made several of these in my home shop with a crappy drill press and couldn't get them perfect enough except by luck it seemed. I finally had a shop I use for business stuff make a pair for me.
    Attached Files Attached Files
  19. #16
    new hampshire
    Default idler arms
    I just had 10 idler arms made if anyone else was in need of a set. I keep all of the parts that you may want for your spare kits like steering arms trailing arms and most of the body parts in stock
