Page 5 of 5 FirstFirst 12345
Results 161 to 162 of 162
  1. #161
    Liked: 1875
    The requirement for a minimum 1.375 tubing is still there:
    9.4.5.F.
    Exceptions for Formula Cars and Sports Racing cars
    Any roll hoop design which does not comply with the specifications in 9.4.5, will only be considered
    if it is accompanied by engineering specifications signed by a registered engineer stating that the
    design meets the stress loading requirements below. No alternate roll hoop will be considered unless
    it contains a main hoop having a minimum tubing size of 1.375” x .080” wall thickness
    . The roll bar
    must be capable of withstanding the following stress loading applied simultaneously to the top of the
    roll bar: 1.5 (X) laterally, 5.5 (X) longitudinally in both the fore and aft directions, and 7.5 (X) vertically,
    where (X) = the minimum weight of the car.
    i would take that to mean in essence that no car will be allowed to use main hoop tubing that is any smaller than the 1.375 x .080 specification.
  2. #162
    Liked: 1875
    I believe that the 1.375 only requirement came in sometime in the late '90's ( if I remember correctly Phil Creighton was on the Comp board at the time and importing the Tattus), so most likely an alternative design permission is on file in Topeka. You will need to get someone to make an exact copy of an existing hoop off of another '05 VD ( assuming that it was different in previous and subsequent years), and also assuming that that chassis design was not a UK-only design.
