    Senior Member BrianT1's Avatar
    St. Charles, Illinois
    Liked: 179
    Default Zetec Engine Seals
    In the past the Zetec engine required seals from either Elite or Quicksilver. Is that still the case for SCCA National competition. I can't seem to find anything in the GCR requiring the seals.
    Any information would be great.
    Chatham Center, New York
    Liked: 862
    I believe seals are not required for SCCA club events. I think since virtually all of the Zetecs built are either Elite or QS, they'll have the seals on them anyway.
    Senior Member SilverCarbir_FC26's Avatar
    Oconomowoc, Wisconsin
    Liked: 31
    I hope seals are not needed since I'm building my own engine.
    Because racecar...
    Liked: 862
    The seals are in effect QS and Elite's representation that the motor is legal and built to a certain HP range. They are still required in F2KCS.
    Liked: 31
    Quote Originally Posted by Bob Wright View Post
    If that's the case and some how want to run F2000 pro series I'll build my motor and pay them to dyno it and put their stamp of approval on it that it meets a certain power level. I'll bet that would happen though.
    Because racecar...
    Saratoga Springs NY
    Liked: 38
    Default zetec
    Quote Originally Posted by SilverCarbir_FC26 View Post
    I doubt either engine builder would seal your engine just by running it on dyno without opening it up and making sure it had all the proper parts inside and that they met the requirements of the class. I think you will have to pay the going rate for a rebuild from either one of these engine builders in order to get a sealed motor.
    HT
    Member QS's Avatar
    Frederick Maryland
    Liked: 6
    Per Bobs rules we can seal your engine for his series based on the HP it makes on the dyno.
    Erik Oseth
