    Northern California
    Default Source for Differential Bearings
    Trying to find a good source for the differential bearings and not having a lot of luck. Was looking at SKF W 61913-2Z or the Timken 9313K but so far my inquiries have gone unanswered.
    Anyone have a good source or a recommendation for a different bearing that would fill the bill here
    PLANO
    Liked: 35
    Hey Joe.
    On our TRE diff we use 100 x 65 x 18
    On our TRE/RFR diff we use 90x 55 x 18
    Are these close to what you are looking for
    Scotty
    Est. 1990
    Taylor Race Engineering
    Liked: 1879
    The SKF W61913 is 90 x 65 x 13, with a stainless steel body. You could replace it with the standard (ferrous steel body) 61913. Either are available through any decent bearing dealer, with the standard steel version being much more common to find ( and cheaper) at dealers such as Motion Industries. However, beware of Chinese knockoffs labeled as supposedly being SKF.
    Northern California
    Thanks for the information guys.
    I was a little confused about the width of the bearing since it appears the seat on the differential is only 15 mm wide. I have the Qualfi differential.
    I found the bearing through VXB Bearings
    NationSkander California Corporation has served the industry by supplying all kinds of Ball Bearings. Ball Bearing businesses have been our family tradition since 1958. We import, export, wholesale and distribute bearings under our VXB brand name
