    Batesville, Arkansas
    Default Valve Spring Compressor for Lotus Twin Cam heads
    Could anyone on the forum please direct me to an American made Version of a Valve Spring Compressor for a Lotus Twin Cam Cylinder Head? Thanks, Jerry
    Senior Member rv greg's Avatar
    Puyallup,Wa.
    Liked: 9
    Default valve spring compressor
    I use one like below and works well for the twin cam with the head off.
    http://www.ebay.com/itm/like/3615553...&ul_noapp=true
    Senior Member Nardi's Avatar
    Southeast
    Liked: 121
    I have a small valve spring compressor that works a bit like a bearing puller does. Legs that grasp the spring and a threaded handle that allows you to compress the spring. Makes sense in my head, not too sure I am being clear tho. Works head on or off.
    Santa Cruz, CA
    Liked: 23
    I have a new one of these from Snap-on that wouldn't work on the pushrod kent head. Lemme know if you want it.
    'Stay Hungry'
    JK 1964-1996 #25
    Southeast
    Liked: 121
    That's the tool I was describing!
    San Diego,Ca
    Liked: 492
    Default compressor
    Those will not work on twin cam heads. The valve springs are down in a pocket for the cam buckets.
    Roland Johnson
    San Diego, Ca
    I have one like Tim's. Not from Snap On. I added a U Bolt to keep the legs tight against the valve spring cause they would always pop off just as you got 1 of the keepers out.
    Works great if there is room to get it on the spring.
