Results 1 to 13 of 13
    Hoschton, GA
    Liked: 757
    Default Front and rear rotor source - '75 VD
    I'm having a bit of trouble finding front and rear brake rotors for my '75 Van Diemen. The parts that Pegasus supply don't match the dimensions of mine. The rears are closer but not close enough. The rear rotors on the car look like modified road car parts and have some some pretty scary looking modifications to them.
    My front discs are just over 9" diameter and fit on the standard triumph upright/hub assembly. From the inside friction side of the disc to the top of the top hat measures approx 1.3"
    The rears are the same diameter but the overall height as described above is approx 1.07"
    Thanks!
    Liked: 270
    Default Front Discs
    Fronts are Spitfire from about late 60's - some were thinned up but I doubt that a 75 was done as most were school cars out of Jim Russell. They should be same as a 78-80 VD.
    Any of the British car spares folks like Moss Motors etc.
    Rears should be standard AP racing inboard discs that fit everything inboard Mk9.
    See the post below for the caveat.
    Tacoma, WA
    Liked: 322
    Quote Originally Posted by Phil Creighton View Post
    Not everything. My car has Girling calipers and uses 10" rotors (very tough to find).
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Liked: 270
    Default Rear
    Thats correct - early 70's were Girling. Thought the 75/6 VD were AP at the rear.
    Sarver, Pa
    Did you try Coleman racing ?
    Hoschton, GA
    Liked: 757
    Thanks for replies. I think I've found what I need from Dave Bean for the front end. Can't seem to find a suitable rear match but am working on it!
    Brown Deer, WI
    Liked: 47
    Ian Lenhart
    Level 11 Creative
    www.level11creative.com
    lenhart06@yahoo.com
    australia
    Default rear disks
    the rear disks on my RF 75 are from a mazda mx 5 ( I think you call them a miata )
    I cant remember if they where front or rear but a brake shop should be able to comfirm the dimensions . the hat is the correct offset but we had to machine the outside OD
    do you have any picks of your car ?
    MAL
    Liked: 123
    There is a Brembo book that lists all the OEM brake disc dimensions. I know it exists because I used it on line to find a disc that I could make into a rear disc for a Chinook. Last time I looked I couldn't find it, sadly. Just a possible clue.
    Hoschton, GA
    Liked: 757
    I did source rear rotors, thanks. I still have an unused set if anyone needs inboard rear brakes.
    australia
    Default rear discs
    do you know which car the rear discs you sourced where from?
    Hoschton, GA
    Liked: 757
    I bought the discs from Cambell Motorsports -
    https://campbellmotorsport.sharepoin...rakeDisks.aspx
    Santa Rosa, CA
    Liked: 268
    Default brake disc
    Coleman will make nearly every size used at a reasonable cost and can make hats as well to adapt for applications that used a built in hat as in older cars.
