Results 1 to 5 of 5
Thread: Penske shocks
    Member Jay Jacobellis's Avatar
    Highlands Ranch, CO
    Default Penske shocks
    I have 7500 series shocks on the front of the Vector I just bought does anyone have a starting point for how much nitrogen pressure I should start with
    Shelbyville, TN
    Liked: 93
    The manual doesn't spec a pressure. I would guess 100 lbs as a starting point although I personally would use less. Additionally, I use compressed air, not nitrogen. I know people will disagree with that but my sources say it doesn't matter that much.
    Scott
    Stanford, KY
    Penske says 100 psi or pressure as required by track. I have never run 100 in anything, but have run low as 30 and as high as 80. And that is in everything from a FST up to a 3000 lb stock car. The pressure just adds stiffness or spring rate. I would start at 50. That is what works for us, I am sure others will have different opinions.
    Liked: 1399
    The correct pressure can only be determined by a little shock dyno testing.
    What you need to do is figure out what the maximum velocity the shock is likely to see on the front of a FST or the rear. Then on the dyno you simply stroke the shock at that velocity and listen for when the shock starts cavitation.
    The same shock on say a FF would require a minimum of 150 psi.
    If you operate the shock at velocities that cause cavitation, the shock becomes ineffective. It no longer dampens suspension movement.
    The friction in a VW front suspension, under loads, gives a lot of dampening, so the shocks are not that critical if they are slightly under pressurized.
    Lafayette INdiana
    Liked: 295
    What should they be on a 98 van dieman used for autocross?
