Results 1 to 10 of 10
    West Sacramento, California
    Default Balance bar assembly
    Group, can anyone suggest a balance bar assembly that I can adapt to my MK10 LeGrand FF. Have nothing at the moment just about a 10 inch space between the pedal and the master cylinders.
    Mike Summers
    Liked: 3787
    Liked: 610
    Default Balance Bar Assembly
    New Jersey
    I have a question on the subject. When adjust the Pegasus part to the stated 2.5" Centerline, there is space between the clevis and pivot tube, which would allow the adjustment to move about 1/4" . I've always threaded them closer, so the clevis body basically rubs the end of the tube, without binding. How should they be adjusted? I can get some pictures to explain if needed.
    Liked: 610
    Default Balance bar adjustment
    Adjust the clevis(s) so that they touch the side of the tube just as you reach the maximun angle, ie, one master has failed while the other is providing pressure.
    This is what a twin master system is designed to do, provide pressure to one circuit if the other fails.
    If it touches too soon it will interfere with that process.
    New Jersey
    Thanks, I'll try that when I have it assembled. That will leave some "slack", but I guess in practice there is no problem with the pivot walking, and the bias varying?
    NW Colorado
    Liked: 30
    Default Summit Racing
    Lots of options...
    http://www.summitracing.com/search?S...=balance%20bar
    John Mihalich, Jr.
    Liked: 610
    Default balance bar
    Quote Originally Posted by stephen wilson View Post
    As long as the distance from the clevis to the "bearing" remains the same, the balance that you feel will not change. This little amount of slack around the tube in the pedal will have no "real world" effect on the type cars we drive.
    New Jersey
    Ah, brain fart. It doesn't matter where the pivot is in the tube, as long as the distance to the clevises doesn't change. Thanks !
    PLANO
    Liked: 35
    Here ya go Mike Mike. I also have them in stock..
    I also have some diagrams if you need them.
    When running on pavement, you want the front tires to lock-up with
    slightly less pedal pressure than the rears. This will help to keep the car
    stable and prevent it from going into a spin.
    1. Loosen both of the jam nuts on the adjusting shaft
    2. Turn the adjusting shaft so that it advances the
    spherical bearing closer to the selected master cylinder, increasing
    the braking force produced by that master cylinder . The
    balance bar must be adjusted with the pedal in the relaxed position
    3. The balance bar has a large adjustment range. However, if you find
    that what you need is outside of the adjustment range, you will need
    to make a master cylinder bore size change. There are three possible
    changes that can be made (See below). All changes will allow the
    spherical joint to move back towards the center position.
    a) Decrease the bore size of the master cylinder closest to the spherical
    joint by 1/8". This will decrease the amount of pedal force
    required from the foot and increase the amount of pedal travel.
    b) Increase the bore size of the master cylinder farthest from the
    spherical joint by 1/8". This will increase the amount of pedal force
    required by the foot and decrease the amount of pedal travel.
    c) Increase the bore size of the master cylinder farthest from the
    spherical joint by 1/16". Decrease the other master cylinder bore
    size by 1/16". This will maintain the amount of force or pedal travel.
    4. When satisfied with the adjustment bar location and force distribution,
    tighten the jam nut . A jam nut is not required
    when a Remote Brake Bias Adjuster is used.
    Force Distribution (2.5" Clevis Center-to-Center)
    Spherical Joint Position Left Clevis Right Clevis
    3/8" left-of-center 65% 35%
    1/4" left-of-center 60% 40%
    1/8" left-of-center 55% 45%
    Centered 50% 50%
    1/8" right-of-center 45% 55%
    1/4" right-of-center 40% 60%
    3/8" right-of-center 35% 65%
    Scotty
    Est. 1990
    Taylor Race Engineering
