Results 1 to 10 of 10
    Contributing Member Don Denomme's Avatar
    Massachusetts
    Default Hewland Mk8/9 case work
    Looking for someone who can clean and dress an old Mk 8/9 case. One of the lower mounting holes had a crack and was professionally welded. Since you can't get the original cases any longer, I would like to have this case cleaned, drilled and preped as a spare. Aluminum cases are expensive and still require a great deal of machining before use.
    Never done this before. Always got a new case when a crack developed. Suggestions would be helpful.
    Don
    Williams Race Developments, Lee Williams??
    Memphis, TN, USA
    Liked: 416
    Call Scotty at Taylor Race Engineering. 800.922.4327
    Massachusetts
    Thanks guys. Tried Scotty several times with no call back. Williams knew exactly what I needed and has several Mk9's in the shop having the same work done. I'll try them.
    Don
    Fallen Friend Swift17's Avatar
    Plantation, Florida
    Liked: 232
    Quote Originally Posted by Don Denomme View Post
    Williams knew exactly what I needed and has several Mk9's in the shop having the same work done. I'll try them. Don
    .... and
    If you need new shift forks go for them from Lee and replace at least, 1/2 & 3/4 ... Just made a purchase and just looking at the quality, you can see the upgrade .........
    England
    Buy an old VW beetle case to rehouse the internals most cases eventually fracture with age as well as an incident or 2
    Currently rehousing the March gearbox into 1 of 3 cases acquired for the future
    there are single and twin filler cases and they do have different bearing around the pinion.
    Small machine mod needed to the reverse idler i recall to do to convert Beetle case to a racing case
    Contributing Member CF56's Avatar
    Gilbert, SC
    Liked: 56
    Dan Taylor
    Taylor Driveline Service
    972-838-7054
    Kevin
    Crossle 35F
    Van Diemen RF02
    Contributing Member dtargonski's Avatar
    minooka il
    Default hewland case
    currently listed mk8/9 main case on ebay @ $375, saw it earlier today...
    http://www.ebay.com/itm/Hewland-Form...f0917c&vxp=mtr
    (not mine btw!)
    Senior Member SCOTTY81's Avatar
    PLANO
    Liked: 35
    Don .
    Sorry I missed your calls. did you call or e mail me.?
    We have around 20 cases prepped and ready to go if you are still interested.
    Once again I am sorry if I missed your call
    scotty
    Scotty
    Est. 1990
    Massachusetts
    Hi Scotty,
    Thanks for the followup. My case only needed cleaning and one mounting hole drilled out. Case is already at Lee Williams shop.
    Don
    WRD
