Or drive shafts
Checking to see if anyone has new ones ....or
Or drive shafts
If for a DB-4 Doug at Fast Forward.
Verify the splines before ordering. If using very old style straight plunge CV joints (common on 70's/80's cars) you will probably need to have them made as they are 22 spline and almost unobtanium. If using the VW 411 style (33 spline) you can have them made to length by any number of off-road dune-buggy shops in your area. These may or may not be gun-drilled so be specific. They also may be a bit heavier but will not break. Other options are to go to John Taylor at TDI or Doug Learned at Fast Forward.
Thanks Charles and Steve they are 32's
to my knowledge they have never been changed nor seen any abuse.....however
