I am considering adding this to my car. I have a Pertronix ignition. Is it a good solution to control over revving in 2nd(forcing me to shift)? I presume it will not help with downshift over revving. Thanks in advance for the help.
Mark, that's the rev limiter I installed on my car, although some folks have had problems with the Pertronix.. At the time I decided I wanted a rev limiter, it was on sale for (edit: it was $125/shipped) on amazon, so I figured I'd give it a shot. Anyhow, it is working fine, so far. Search "rev limiter" for more info.
I ordered one from JEGS.
I got the rev limiter. How does this "black box" work? I just hook it up to both sides of the coil and it somehow kills the spark?
Given the connections (+Vdc, coil -, and ground), it steals the spark by selectively grounding the coil negative side when the rpm is > than the setting. Grounding the neg side of the coil will keep the coil current flowing and not allow the plugs to fire. Apparently the logic of the control unit is configured to "steal" only some of the time...What I want to know is how does it "steal"(the manufacturers term) spark.
I've never used one, it's just the connections only allow for the "spark stealing" to occur one way.
I am on my second one. The first one worked fine but when I installed solid copper wires it made my engine misfire. Make sure you use resistor wires.
