Results 1 to 6 of 6
    Senior Member Daniel Thompson's Avatar
    Montreal, Canada
    Default Brake master cylinder question (Lola T492)
    What size master cylinders are typically used on a car with LD65 front calipers and LD20 rear calipers. I want to get the best size the first time...
    Member Tony Sleath's Avatar
    Detroit
    When we had a Swift DB2 in the 90s with those same calipers I used a 13/16 front and 3/4 rear.
    Liked: 271
    Default Cyls
    Just checked a Royale in the shop with those calipers and its 0.7 Front and 3/4 Rear.
    No balance issues that we are aware of!!
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default master cylinder
    Phil,
    For most, I think you will find the .70" bore a little small to push four 36mm pistons and not have a driver unhappy with the long pedal.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    Liked: 271
    Default S2
    What can I say! no complaints from the customer so far but you are probably right. He has bigger cyls on his DB2 with LD65s all round.
    Phil
    Montreal, Canada
    Thank you gentlemen.
