Results 1 to 11 of 11
Thread: Lug nuts
    Member Mariomark's Avatar
    Louisiana
    Default Lug nuts
    I have 2 sets of Cromodora CD 30 rims. The lugs for these wheels have a 3/4" wide shank and are aluminum. Does anyone know where I can get some spares?
    Liked: 123
    What thread are they? You mean the lug nuts themselves are aluminium? I made a bunch of lugs like that up one time, for a sports racer I have. I used aluminium hex stock and a lathe. I'd be highly surprised if you could buy them off the shelf. I'd be happy to dig mine out and see what I actually have, if you need them
    Syracuse, NY
    Porsche uses (or at least did in the late 80's, I don't know about currently) aluminum lug nuts off the factory line. No idea on the stud size or thread pitch, but they have a semi-circular mounting face and take a 19mm socket.
    As a side note - I know way to many cases of these aluminum lug nuts breaking or galling and being a PITA to get off without damaging the wheel. If you decide to go this route, consider them wear items and replace them as soon as they start to squeak.
    Louisiana
    It is a 7/16" lug with a 3/4" wide shank and flats and a 28 mm. shoulder where it mates the wheel.
    [/IMG]
    Tacoma, WA
    Liked: 323
    have you tried these guys?
    http://www.gorilla-auto.com/lug-nuts
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Louisiana
    I've looked through Gorilla, all the lugs with .740" shank are larger than 7/16". Thanks. I may have to convince someone to make some.
    Tacoma, Washington
    Liked: 210
    Aluminum LUG NUTS!!! ???? Wholey Galling Batman!!!
    Louisiana
    Steel would be great to find. Unless there was a reason for using Al with the magnesium rims. I just don't know. Brian if you have some 3/4 wide shank homemade lugs I just might be able to make them work with washers. I would appreciate it if you had the time to dig yours up, thanks. My pic attempt did not work so I'll post a link.
    http://i942.photobucket.com/albums/a...s/DSC01129.jpg
    http://i942.photobucket.com/albums/a...s/DSC01130.jpg
    Sagle, Idaho
    Liked: 180
    Anti-seize the hell out of them if you end up using al.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
    Liked: 123
    I finally found mine, but alas they are the wrong size shank... Sorry!
    Sagle, Idaho
    Liked: 180
    Looked up the ones for the 911's and they are 12mm, so no luck there.
    Manufacuring them wouldn't be inmpossible but you'd want a cnc mill for the hex section.
    Lawrence Hayes
    Hayes Cages, LLC
    Sagle, ID.
