Thread: HANS devise
    greenville, sc
    Default HANS devise
    I may be treading on what was an old post. but here goes anyway.
    Is the general consenses that the 30 degree is the one that works best in our cars?
    Your comments appreciated as I will soon be purchasing one.
    Bronco
    Senior Member drdestructo's Avatar
    White Salmon, WA
    Liked: 30
    Yes
    Sarver, Pa
    If I was able to do it again, I'd buy the Safety Solutions !
    So.Cal.
    Default Best case might be.........
    ..........to try the devise on with you in the car and helmet on and belts tight.
    atlanta, ga
    Liked: 136
    Default No
    It all depends on the reclining angle of the driver: Big folks in short cockpits tend to sit much more upright (bordering on failing a broomstick test), while shorter drivers are seemingly laid right out.
    The more reclined, the greater the HANS model #.
    Often times large drivers in a very reclined position have the front edge of their helmet contacting their chest. This presents it's own problems with fitment.
    I have run the same model 20 in FM, DSR, FC, ASR, and FB.
    I even had HWGIC Jim Downing give it a look over and he proclaimed everything good-to-go. Can't get any better than that!
    Senior Member jaltaman's Avatar
    Salt Lake City
    Liked: 66
    Default I use the 30
    ... but am just a bit taller than Coop.
    Glenn also makes a good point - be sure you can pass the broomstick test when you're giving it a try. Just purchase it from a reputable vendor and you can always return it within 30 days it for the proper size if you happen to get the wrong one initially.
    greenville, sc
    Default Hans
    Thanks guys, I'm gonna try the 30 first if thats too much angle I'll be able to trade for a 20.
    Thanks again.
    Tony
