[quote He hides my tools, won't offer any setup advice and he DOESN'T LISTEN!!! And...he won't take my advice -- wait a minute, maybe he's smarter than I thought./quote]
OK here you go, I'm sure my Citation setup will work on your VD as we all know they are so similar.....
LF Spring = 800 Lbs
Rf Spring = 300
LR Spring = 185
RR Spring = 185
I run the high spring rate on the left front help deal with the LF loading going into the toe of the boot. Coincidentally data analysis shows unequivocally it also helps press the lf tire onto the pavement in the off camber heal of the boot and the 90.
I came up with the rear spring rates as I was looking for something softer than the normal 600 Lbs spring to deal with the bumps in the last turn. I found the 185's in my FV parts bin. It was a bit of a trick to squeeze the 12" long springs down to fit in place of my 4" springs but I also had my official FV spring compressor and that seemed to work just fine. You are welcome to use it if you like. Necessity is the Mother of something or other....
BTW, this has not been approved by Lathrop, Minor, Langbien, Starke (SR or Jr) or Schwietz.
SteveO
