    Indianapolis, Indiana
    Default Fuel cell hardware question ---
    Does anyone know of an aluminum filler neck (that someone fabs) that could be attached to a VD fuel cell replacing the long rubberised "chicken neck" arrangement used on the RF 97.
    Ideally this would be a flanged metal filler with radially drilled bolt holes, then a second matching piece that would go inside the cell and fit against the flanged filler, sealing things. The tough part is the size; the top of the VD tank is only 3" wide (and that's where the fuel goes in).
    This could be fabricated, I know, but is there some proprietary part alread out there -- an airplane piece, maybe?
    Thanks, if anyone has any thoughts ---
    Chris Crowe
    New Jersey
    Have you checked ATL, they have a mini fill neck that looks like it may work ( or Fuel Safe ).
    Default Duh ---
    -- well, I certainly should have figured this one out. Will contact them in the AM. Thanks for the heads-up!
    Chris Crowe
    Liked: 1880
    Gray hair taking over your life?
    Default It is indeed, Richard!
    -- and the beast IS coming along. But it's slow when you're old and alone. What happened to all those nice young Wisconsin kids who used to live in my garage about forty years ago?
    Best regards,
    Chris
    Liked: 1880
    Quote Originally Posted by Christopher Crowe View Post
    -- But it's slow when you're old and alone.
    Don't you mean old and SLOOOOOOOOW ?
    Default I guess so ---
    -- outside the car. Do you have any idea fast old racers were?
    SOOOOO FAST...
    Crowe
