Does anyone know of an aluminum filler neck (that someone fabs) that could be attached to a VD fuel cell replacing the long rubberised "chicken neck" arrangement used on the RF 97.
Ideally this would be a flanged metal filler with radially drilled bolt holes, then a second matching piece that would go inside the cell and fit against the flanged filler, sealing things. The tough part is the size; the top of the VD tank is only 3" wide (and that's where the fuel goes in).
This could be fabricated, I know, but is there some proprietary part alread out there -- an airplane piece, maybe?
Thanks, if anyone has any thoughts ---
Chris Crowe
