I'm being told by my engine builder that I should not be using regular gas anymore (like I did last summer). I'm not concerned about the higher octane that AvGas comes with.
Most people at the track run pump gas (from what they report). At the same time they only rebuild their engine when it's about to blow or it's blown. All that to say I'm not sure how much they care about maintaining a healthy engine.
The engine builder has observed some wear since the last rebuilt (last season). Also I was overheating like crazy and apparently leaded gas can help reduce overheating issues. I've improved the cooling of the heads, but at the same time I want to make sure I will not overheat again.
The drag shop guy mentioned that leaded gas helps with cooling too, it's something to do with the way leaded gas or racing gas burn. It's something he's seen on the dyno from what he reported.
Either way both that guy and my engine builder are very convinced I should not be using street gas, but leaded gas.
