Came across a cool (and free!) airfoil analysis program a few weeks ago .. JavaFoil;
http://www.mh-aerotools.de/airfoils/javafoil.htm
I used it to model the 2 element wing on the rear of my DSR, and might have found a higher downforce, lower drag configuration!
Refer to the flow field pictures attached ...
Previously, I had my main plane about 5 deg down into the flow, and the upper element about 15 deg down.
I had Cl of -2.4 and Cd of 0.044 (based on whatever scale I happened to be running the program at).
After experimenting with the program for a bit, I discovered that actually pointing the main plane UP into the flow 1 deg, and the upper element down 28 deg, my Cl went up to -3.0 and Cd went down to 0.033
It will be interesting to try out this config at the track to see if it's an improvement!
