Results 1 to 28 of 28
    Muncie, Indiana
    Liked: 985
    For Sale Alignment Flag System
    I have an alignment flag system which I am not using. This is the system referenced in the Swift set up manual and what we use on the Citation for camber, toe and even ride height. This should bolt up to any hub with a 3.75 bolt circle. $225.00 plus shipping.
    John
    racinglaw@aol.com
    765.748.4848
    Muncie, Indiana
    Liked: 985
    Default Still Available
    System remains available.
    Jupiter, Florida
    Liked: 79
    John: Can you please describe the flag system?
    Bob
    Muncie, Indiana
    Liked: 985
    The system has a flag pole that about 5' long and has an aluminum flag that is about 30". There are two uprights which attach to the wheel hubs. This is a copy of the system used by Swift. If you would like pictures I will get some next. Weekend. I have two of these, am selling one.
    John
    Atlanta, Ga
    I happen to have some pics of a flag system that will give you the idea. This one can from Comprent so it's probably not exactly the same one being sold, but it will give you an idea.... (vertical gives you camber, horizontal gives toe). These work great.
    Sean O'Connell
    1996 RF96 FC
    1996 RF96 FB
    2004 Mygale SJ04 Zetec
    Muncie, Indiana
    Liked: 985
    Thanks, yes that is very similar to the one I have for sale!
    John
    Jupiter, Florida
    Liked: 79
    Thanks for posting the pictures.
    Showever, after seeing them, I have determined that since I live in Florida, there is no where for me to store this.
    Muncie, Indiana
    Liked: 985
    no problem, but what the hell does living in Florida have to do with this?
    Muncie, Indiana
    Liked: 985
    Default BTT
    Still available!
    Jupiter, Florida
    Liked: 79
    John-just saw the post about living in FL. Good question, but the answer is small garages, no basements, 2 kids equal minmal storage space.
    sorry-no where to put things anymore.
    Bob
    North Carolina
    Liked: 19
    Default dummy shocks as well?
    John,
    In the Swift set up you use dummy shocks and of course block the steering at straight ahead so s to adjust the toe.
    What do you do about dummy shocks when using this system on another car? Fabricate them so the suspension is held at ride height?
    Hudson, Ohio
    Liked: 208
    Does this system require that the car be on a flat surface, ie. pads?
    Or, how do you set the zero position for toe?
    Muncie, Indiana
    Liked: 985
    Yes, I made up some struts which I set to the length of the damper at ride height. Mine are tubular with rod ends, so they are adjustable, however my DB1 simply had strap steel. As for the steering we have some pieces of aluminum tubing that was sliced through the center which are installed on both sides of the rack.
    When we do this we will usually have the car supported on stands, however you can leave the shocks in place, block the car up on the uprights and go about the alignment.
    North Carolina
    Liked: 19
    Default measuring toe
    Thanks John - that's what I figured you might do.
    Ralph - you can set a car up with this equipment on the side of a mountain since its an entirely geometrical system. Once the steering is centered, you can measure the toe at each side by rotating the flagpoles to the horizontal (as opposed to the vertical which is when you measure camber), and measure the gap as before.
    Its a neat system.
    Muncie, Indiana
    Liked: 985
    Yes, thank Jeff I failed to answer the question. The car does not have to be level to do the set up. IN fact, when Lathrop does a set up he even goes so far as to set ride heights. I am always amazed at how close the car is when I put it on the scales. When the car was first completed I rolled it on the platform and there was nothing to adjust!
    Hudson, Ohio
    Liked: 208
    Default Size
    John:
    How large is this device and how might it impact shipping? Can it be shipped or does it need to be picked up?
    Muncie, Indiana
    Liked: 985
    I will check to see what it would take to ship. I dont know if USPS will take something that long. The flag bolts up to the pole so that part will be easy.
    Houston
    Default Setting Ride Heights
    John
    racinglaw@aol.com
    765.748.4848
    OK, I'll bite.
    How are ride heights set with this alignment flag system?
    Rick
    Muncie, Indiana
    Liked: 985
    It can be done with or without this system; the measurement is taken from the top of the bell housing to the top of the upright and then caclulated from known dimensions including the tire diameter. I have never set it this way however Steve has many times very successfully.
    Senior Member Steve O'Hara's Avatar
    Default Flag system
    I just acquired one of these systems with a car I bought and I'm looking for help with finding a copy of the written instructions for using the tools.
    Anyone out there that can help?
    Steve O'Hara
    Senior Member Ken Rozeboom's Avatar
    http://www.apexspeed.com/forums/showthread.php?t=19056
    I also have the instructions supplied by Doug Learned for his system which I can email.
    Default flag system instructions
    Ken,
    Thanks for your offer to help.
    Please send the file to steveohara@msn.com
    Maineville
    Liked: 103
    Default Me too
    Ken can you send to me as well as I bought this system from John. joefisher at fuse.net
    Cincinnati, Ohio
    Default Ride height stops
    Joe,
    Give me a call. I have the ride height stops with my flag system that will not work on my DB6 but fit the DB1. Maybe you could put them on your car snap some photos for posting for ther greater good.
    Mike
  25. #25
    Maineville
    Liked: 103
    Default Will do
    Will do Mike, I'll call and stop by to grab them. Thanks!
  26. #26
    Rochester, Mi
    Liked: 6
    Maybe I'm missing something obvious but what the heck holds the system upright and keeps it from flipping over. Especially since someone stated it can be used for toe as well. Just curious.
  27. #27
    North Carolina
    Liked: 19
    Default some additional info
    The system doesn't flip over or rotate because you can wrap a bungee around the brake pedal to create some stiction. This way the poles are easily held in their horizontal or vertical position.
    The images that Sean posted are very helpful if you are trying to figure out how it works, but believe me its essentially bullet proof. In my case I use some Ally strapping with holes at the required separation in place of the shocks to give me the ride height I want.
    JeffW
  28. #28
    Classifieds Super License Messenger Racing's Avatar
    Muleshoe, Texas USA
    Liked: 160
    Default Flag system
    The system I use has large spacers that screw onto the stub axle in place of the wheel nut - but - you leave the wheels on the car and set the car on the ground. You end up with large mounting flanges that sit on the outside of the wheel and attach the flag uprights to. By doing it this way, I ballast the car, set tire pressures and start measuring with the car on the ground. The poles are held vertical or horizontal by chocking the tires as needed. It is very quick and easy to use once you figure it out. It does not, however, set toe front and rear in relation to car center line except to the extent that it is extrapolated from the accuracy of the steering rack lock and prior measurements at the rear of the car to a known centerline.
    JM
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
