Results 1 to 6 of 6
    Williamsburg, VA
    Liked: 17
    Default NJMP Lightning gears?
    I've looked thru the usual places without finding a definitive answer. Gears recommendation for monoposto FF?
    Hingham, MA
    I have run there only once and used Watkins Glen ratios based on conversations with others (S2 and modern FF). They seemed to work well although I did make a note that a higher first gear might be preferable.
    Ivan Frantz, Merlyn 11A
    Contributing Member Tigaman's Avatar
    Virginia Intl Raceway
    Liked: 67
    Which is why I like to use Lime Rock gears for Lightning, Summit gears for Tbolt.
    -Peter Krause
    1984 Tiga SC
    www.peterkrause.net
    "The Driver is the Greatest Performance Variable in the Racing Equation"
    Senior Member AlanVDW's Avatar
    Ramsey NJ
    Liked: 23
    @ Lightning, I have 19/33, 21/30, 23/28, 25/25.
    I want to change to 19/31, 21/30, 23/27 or 24/28, 26/26, as soon as I can buy some more gears.
    Van Diemen RF 79 #? Van Deimen RF 78 #231
    It's not how fast you go.
    It's how well you go fast.
    New York
    Liked: 157
    Bill holds the Lightning lap record for FF, set using his Watkins Glen gears. Not saying those are optimal for the track, because we havent been back, but certainly close.
    PS, Alan, I assume the numbers you gave are for a 9/31 R&P? For a 10/31 a 1:1 gear is rarely needed.
    Ramsey NJ
    Liked: 23
    Yes, a 9:31R&P. JD King suggested I use the above gearing as my gears are off a bit. Third gear needs to be taller for the bowl.
