Results 1 to 12 of 12
    Parker, Colorado
    Default Typical FE Dyno and Standard Gear Charts
    One of the most common requests is for us to share typical dyno and the gear charts with the community:
    Typical Dyno Curve:
    http://sccaenterprises.com/tech%20bu...yno%20Perf.pdf
    the 00's are missing from the RPM's. Don't get too hung up on the HP numbers, correction factors / altitude etc have an effect and we are not out to impress anyone. Our dyno is (according to Super Flow) being used with as much accuracy and repeatablity is any customer they have ever had...day to day matters...big numbers do not.
    Gear "Sawtooth" chart:
    http://sccaenterprises.com/tech%20bu...FE%20Gears.pdf
    Pick your shift point (see dyno graph ) and draw the shift point drop down lines in to complete your sawtooth...(note the drop 3-4...hint hint...)
    Sincerely,
    Erik Skirmants
    SCCA Enterprises
    Cleveland, OH
    Liked: 111
    Thanks Eric. That is a big help to me right now.
    Thanks to your time for working so tirelessly to keep the playing field even.
    jim
    Contributing Member Eric Cruz's Avatar
    Barhamsville, VA
    Liked: 59
    Amazing how the torque and power curves always seem to cross at 5250... Thanks, Erik!
    Best regards,
    Eric
    If you don't think too good, don't think too much.
    - Ted Williams
    Parker, Colorado
    Amazing coincidence...it does for the SRF too!!! WOW...buy a lottery ticket...wait...BSME from Michigan State...wait...it's almost back...now I remember!!!
    Power (hp) = Torque (ft-lb) * RPM / 5252
    Sincerely,
    Erik Skirmants
    SCCA Enterprises
    St Cloud, Fl
    Liked: 136
    Ok, here is a question for you edumacated racers...should the shift point be where you drop down to the highest (or just below it) point on the torque curve, or is HP more important then torque for achieving top speed in the quickest possible time?
    John
    Contributing Member Billy Wight's Avatar
    San Diego, CA
    Default Road Thrust
    John
    John,
    The best way to do this is by creating a spreadsheet that calculates road thrust. You can do this by taking the torque curve, gear ratios, and various other parameters (tyre diameter, primary engine reduction, etc). Your shift points will be where the lines cross for each gear. In the example below the lines don't cross so you will want to shift at redline for this particular setup (this is a DSR). You can get extra fancy and incorporate a Cd and frontal area like the example below for net road thrust that accounts for aero effects too...
    Billy Wight
    Luxon Engineering
    www.luxonengineering.com
    858.699.5313 (mobile)
    billy@luxonengineering.com
    Cleveland, OH
    Liked: 111
    John
    I am vaguely amazed that someone as fast as you could have questions about cars still. It makes me think I have no hope sometimes!
    jim
    Boulder Colorado
    Default shift points
    Or you could just use the data from your Data system and skip doing all the calculations, and estimates.
    Jim C.
    Houston, TX
    Liked: 68
    Quote Originally Posted by Erik Skirmants View Post
    Erik -
    Any chance of getting this chart updated to show the new 4th gear....?
    MM
    Marshall Mauney
    Milwaukee Region
    Senior Member SStadel's Avatar
    Scales Mound IL
    Liked: 218
    The new gear chart should look something like this.
    Competition One Racing
    racer6@mchsi.com
    Cleveland, OH
    Liked: 111
    Steve, sure that is right? It has the lines in the right places now!
    Linden, Ca
    Liked: 25
    Default 6th Gear
    Hmmm, the chart has a listing for "6th" gear. Get the rumor mills running!
