Results 1 to 5 of 5
    Romeo, Michigan
    Liked: 29
    Default 07/08 GSXR 1000 WIRING HARNESS
    Looking for a stock harness with the rectifier - ECM is optional
    Contributing Member tombeattie's Avatar
    Longwood, FL
    Liked: 6
    Default Make an Offer
    Mike,
    I've got a spare harness with rectifier. Make an offer with or without ECU.
    Sent email but not sure if it went through.
    Tom
    Charlottesville
    I know that I'm reading things into your desire for a harness and specifically a rectifier BUT I have found that if I don't run a separate ground wire from the rectifier ground right to the negative post of the battery I end up prematurely losing the rectifier (and sometimes some wiring). Grounding the rectifier ground to a good firm, clean section of the frame should be enough but electricity sometimes has a mind of its own.
    Hasty Horn
    Senior Member Lincspeed's Avatar
    S. E. Michigan, US
    Hasty - have you found that rectifiers get really hot (unless mounted in a fresh airstream)?
    Clark
    Phoenix Arizona
    Liked: 21
    Default Air flow
    It seems to me that to get the most life out of a rectifier it should be kept cool.
    I am not 100% certain about the inner workings, but I am pretty sure that the diodes in the rectifier lose efficiency as their operating temperature rises. Basically, if the rectifier is cool then it will do a better job of turning horse power into electricity rather than converting it into heat.
    Dustin Wright
    Phoenix Race Works L.L.C.
    www.phoenixraceworks.com
    623.297.4821
