Hello
I´m helping a friend with a pre season setup of a Ralt RT-3 1982 The current front springs seems way to soft for a wing car and wonder if anyone have a clue what to start with setup wise.
The car is in flat bottom / non ground effect setup with original wings.
Tyres are Avon 7.5/21x13 and 9.2/22x13 Avon Crossply.
At the moment there is 250lb/in front springs with a lot of bump rubber
At rear there is something "hard" that´s been cut......
Shocks are Bilsteins, probably from the period
Front rocker ratio is 0,81 (155/190 in/out)
Rear rocker ratio is 0,68 (125/185 in/out)
Minimum wehight is 455Kg
Minimum ground clearance is 40mm
Im looking for
spring rates
Camber
Toe
Ride height / rake
/Henrik
