    Senior Member Henrik's Avatar
    Sweden
    Liked: 17
    Default Lotus 61 radiator brackets
    Hello
    Can anyone please help me with the measurements for the brackets holding the radiator on the Lotus 61?
    I have all the attachment points as all the stubs are still in place from the original framework. I also have an original radiator to test with.
    I need the following measurements
    A: Lenght of tube center of boss to frame tube A=
    B: Lenght of tube center of boss to frame tube B=
    C: Lenght of tube center of boss to frame tube C=
    D: Lenght of tube center of boss to frame tube D=
    E: Lenght of tube center of boss to frame tube E=
    F: Lenght of tube center of boss to frame tube F=
    G: Distance below top of frame tube to centre of boss G=
    H: Distance below top of frame tube to centre of boss H=
    I: Distance below top of line extension top of frame tubes to top off boss I=
    J: Distance centre of boss to frame tube in 90 deg J=
    K: Distance centre of boss to frame tube in 90 deg K=
    L: Distance centre of boss to frame tube in 90 deg L=
    I guess that "I" can be hard to measure if you got the bulkhead in place then measurements from under the frame rails is OK just make a note how you measure. Please see attached picture for which measurement is which.
    Thank you in advance
    Henrik
    "Trying is the first step towards faliure"
    Homer Simpson
    www.hhtech.se
    Sweden
    Liked: 17
    Default Done
    Problem solved and I now have a radiator attached to my car
    I got the maesurements from Åke Axelsson who has an original Lotus 61
    A: Lenght of tube center of boss to frame tube A=210 mm
    B: Lenght of tube center of boss to frame tube B=228 mm
    C: Lenght of tube center of boss to frame tube C=255 mm
    D: Lenght of tube center of boss to frame tube D=245 mm
    E: Lenght of tube center of boss to frame tube E=235 mm
    F: Lenght of tube center of boss to frame tube F=195 mm
    G: Distance below top of frame tube to centre of boss G=65 mm
    H: Distance below top of frame tube to centre of boss H=65 mm
    I: Distance below top of line extension top of frame tubes to top off boss I=165 mm
    J: Distance centre of boss to frame tube in 90 deg J=245 mm Probably 145mm instead
    K: Distance centre of boss to frame tube in 90 deg K=193 mm
    L: Distance centre of boss to frame tube in 90 deg L=197 mm
    Henrik
    Homer Simpson
    www.hhtech.se
    Marietta,Ga.
    Liked: 61
    Default 40th Anniversary of Formula Ford Celebration
    Hey Henrik, Are you getting the Lotus ready so you and Åke can bring them to the 40th Anniversary of Formula Ford Celebration in July?
    Scott Woodruff
    (former) F440/F5/FF/FC/FA
    Sweden
    Liked: 17
    Default FF 40
    I would love to go there and the car will probably be ready but the shipping of the cars from Europe would kill me
    Henrik
    Homer Simpson
    www.hhtech.se
