Results 1 to 10 of 10
    Senior Member Henrik's Avatar
    Sweden
    Liked: 17
    Default Lotus 61 originallity
    Hello all,
    So I have finally got my Lotus 61 in my garage and made a dummy build of the parts from the boxes
    I have some questions about origniallity as I will try to restore it to original condition.
    What colour should the frame be? Someone told me that the Lotus gray was surplus light gray from the aircraft industry after WW2. The rollhop on my car have been replaced but I think I will keep it
    Henrik
    1. I guess that this bracket is cut to fit the more modern low bodywork, should it have the hole marked?
    2. How should the radiator attachments look like?
    3. When I make a new instrument panel what should the joint look like? I have seen panels with leather some with alu panel and some steel with paint finish
    4. What is the marked hole in the centre for? Is the hole to the right original as it doesnt have a chamfer
    5. What are these brackets for? what should they look like?
    6. This bracket looks home made, should it be there and if so how sohuld it look?
    7. I guess that this is orignial
    8. Is this the Arch Motors frame No?
    9. Is this strenghtening original? There is one just like it on the RH wishbone but on underside
    10. Are these calipers original?
    11. Is this swirlpot original?
    12. What are these for?
    13. Is this an original oil cooler bracket?
    "Trying is the first step towards faliure"
    Homer Simpson
    www.hhtech.se
    Sweden
    Liked: 17
    Default Frame colour
    Hello
    I have got answers for the questions above exept for #12 and what colour sould the frame be? Someone told me that the Lotus gray was surplus light gray from the aircraft industry after WW2.
    Henrik
    Homepage uppdated on 081201
    http://hhtech.se/news08.htm
    Homer Simpson
    www.hhtech.se
    Tacoma, WA
    Liked: 323
    OK, now I'm curious.... What are the answers to the questions????
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Sweden
    Liked: 17
    Default Q&A
    1. No hole
    2. It should look like this
    3. Bulkhead /instrument panel should be one piece, panel in wrinkle finish black
    4. Centre hole bat ground. Hole to righ tis "common" for electrics with grommet
    5. Not original should look like this
    6. Original
    7. Original
    8. Yes
    9. Original
    10. Girling 14LF and are correct for your car. Some of these calipers have the inlet on the top, yours have the inlet on the side but both are correct.
    11. Not Original
    12. ?
    13. Yes, for MX/F3 variant
    Many thanks to LFFR.org and Peter Denty
    Henrik
    Homer Simpson
    www.hhtech.se
    Deep River, Ontario, Canada
    Liked: 120
    Default Lotus 61
    Excellent post. Good luck with the project. Ken.
    Tacoma, WA
    Liked: 323
    yes, thanks for the update. It's nice when a question type post is answered (especially nice for archive informaion)
    Looking forward to seeing pictures of your finished project
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Memphis, TN, USA
    Liked: 416
    Might the buttons (#12) be the attachment fittings for the oil tank? Through grommets installed in the supports and then pinned with washers? Have seen this on other cars of the day.
    Charlie Warner
    fatto gatto racing
    Waukesha WI
    Liked: 25
    Default Dash bulkhead?
    I don't think that the upper section where the gauges go is the original shape.
    Should be more of a top hat shape.
    I'm sure Peter can help out with that.
    I restored a 61 then 51 a long time ago and remeber the fun I had doing it
    They are neat cars for sure!
    Sweden
    Liked: 17
    Default Dash
    Do you mean the bulkhed on the pictures above or the pictures of the new dash on my homepage? The measurements for the new one was taken from a car believed to be original #129 mine is #160
    Henrik
    Homer Simpson
    www.hhtech.se
    Waukesha WI
    Liked: 25
    Default the old one
    The new one looks much better!
    Sorry for the confusion
