    Sandia Park, NM
    Default Merlyn 11A rear brake discs
    Does anyone know what OEM part was used for the Merlyn MK11A rear brake discs?
    Senior Member LolaT440's Avatar
    CT
    Default rotors
    I don't recall. But I know Clive at merlyn told me a long time ago there were two types that could have been used. If you hard the Girling or some other, triumph or something. It had to do with the stub axel off set from the centerline, and the diameter of the stub axel flange. Email Merlyn and they will give it to you.
    Sandia Park, NM
    Default rotors
    Thanks I'll try that.
