Results 1 to 12 of 12
Thread: Chain Idler
    Default Chain Idler
    I'm considering introducing a chain idler on my car to make chain adjustments easier. While Googling I came across this:
    http://www.terog.com/case/cihidle.htm
    It's an idler without teeth. Supposedly easier on the chain and quieter.
    Just wondering if there might be any reasons not to use it.
    Russ,
    It appears to be spinning on it's axle (which would be the bolt that attaches it to the frame)with it's own body acting as a bushing, and not spinning on a ball, nor roller bearing, I'd call the manufacturer and find out the load and rpm it could withstand.
    Good point. It says they have "High RPM Bearings". I assumed that meant high quality ball bearings but that may not be true.
    Calgary, AB
    ATK motorcycles used an two idlers on there drive. They held up well even in off road conditions and used off the shelf, easily replaced bearings.
    http://www.americandirtbike.com/atkparts.htm
    Daryl E.
    When I first started Googling, I found several sources of idler sprockets with ball bearings. They were the regular ones with teeth. Then I ran across the Terog Idle Master unit without teeth (referenced in post #1). It looked pretty interesting, but would need to confirm it's specs before using it.
    As an aside, I use a 530 chain on my car and realized after a while that it is the same as SAE size 50 chain. That made searches easier.
    Peoria, IL
    Default Roll Ring
    You might want to look into these:
    http://www.renold.com/Products/Trans.../Roll_Ring.asp
    Not much fabrication required.
    -Kyle
    Barhamsville, VA
    Liked: 59
    Just looking at the picture in the lower right of the webpage Russ linked to, it appears to me that they do include a bearing or two. You can clearly see a part of the snap ring that would probably retain the ball bearing.
    Best regards,
    Eric
    - Ted Williams
    Default The Amazing Ronco Roll Ring
    Quote Originally Posted by Teh_3vil View Post
    -Kyle
    Kyle, That's cool! Makes me think it probably wouldn't work for us because it would be too easy. :-).
    I'll see if I can learn more about it. Thanks for sharing this link.
    Senior Member sidney's Avatar
    Ames, IA
    This may be a great setup for you Russ, since you have sprocket sizes that are similar to one another IIRC. For those of us running a "traditional" driveline, I'd guess that there would be issues with generating less engagement of the drive sprocket using this device. Cool demo video.
    Ian MacLeod
    "Happy Hour: 5:00 - 5:30"
    Tatuus F1k
    Default What's our chain speed?
    I think the Maximum Chain Speed for the Roll-Ring may not be high enough for our use. It's rated between 1,000 and 2,000 feet per minute.
    Anyone know what our chain speeds are? I think my setup (with the intermediate jack shaft) may have lower chain speeds than typical FB/SR set ups, but the math is starting making my head hurt.
    This is probably flawed, but I've figured that:
    At 150 MPH our rear tires are turning about 2,263 RPMs.
    My rear sprocket has 40 teeth and the chain pitch is 5/8". That means that 2,263 revs of the rear sprocket equals 56,575 inches of chain travel, or 4,415 feet per minute, which is too high for the Roll-Ring.
    Anyone want to check my math? I hope I'm wrong, because the Roll-Ring seems pretty cool.
    Barhamsville, VA
    Liked: 59
    Easiest thing is to know the diameter of the rear tire and the rear sprocket that's fixed to it via the axle.
    Car Speed (mph) * Tire Dia / Sprocket Dia = Chain speed (mph)
    [or you could convert everything to angular velocity, then back to tangential velocity, but only Richard would really WANT to do that....]
    Multiply speed in mph by 88 to get feet per minute.
    Best regards,
    Eric
    - Ted Williams
    -Kyle
    I sent an email message to them asking their opinion about using it in a race car. Thier response:
    "My engineer has reviewed this application, and is not in favor of using this product in this situation."
    They didn't elaborate, but I'm not surprised. I think the chain speed would be too high. Also, I think we want as little slack as possible and this product requires slack.
