I have a Titan Mk 6 that I have mostly disassembled and am now reassembling.
Since the suspension arms were disassembled, plated and one a-arm replaced, I need to readjust the suspension.
I know what ride height, caster, camber, etc. that I want to run. I have the chassis on stands and the suspension on the car with no dampers. I have measured and confirmed that the upper upright mounts are the same distance out from the centerline and the same distance back from the front bulkhead (and the pick-up points on the chassis are square and centered on the centerline).
What I propose to do is jack up each corner to the nominal ride height, measure the caster and camber and adjust them to what I want at the lower a-arm. Will this work or am I missing something?
If this is sane, I need the height for the wheel/tire combination used in VFF. If I ever get my car back together, I will be running with SOVREN if that makes a difference. There is still one tire that is used in the front and another used in the rear, right?
Thanks in advance.
alan
