Results 1 to 6 of 6
    Seattle
    Default Lotus 69 FF brake rotor thickness
    I'm restoring a 1971 Lotus 69 Formula Ford and wanted to know what the min and max front and rear thickness for vintage Formula Ford brakes are. Is this dictated by rules, original design specs or both?
    Please advise.
    Thanks...Keith
    Liked: 123
    Cars that had Girling 14lf or lockheed/ AP LD-20 calipers typically used a rotor that was .375" thick new. Cars that used AP LD-19 calipers used rotors that were .280" thick new. There aren't really rules for how thin they can get - people often might use .25" rotors with LD-20's (maybe with pad spacers), for example, to get a bit lighter weight. With LD-19's .180" is probably as low as you would want to go.
    Seattle
    So if I have Girling 14lf brake, what is the Max thickness in pad I can use if my rotors are approximately .350" thick?
    Thanks for your assistance.
    ...Keith
    Liked: 123
    for that you'd have to measure. Probably any off-the-shelf pads for those calipers will fit. FWIW I have aluminium Girling 14LF equivalent calipers on a sports racer, Hawk pads, and .45" rotors. It all fits.
    Arlington, Texas
    Default Lotus 69 FF
    I have body molds including the tail as well.If you need bodywork give me a call.By the way a Lotus 69 uses Triumph Spitfire front rotors at .310 thick.I stock those as well and just machine them for whatever the application calls for.M.Sauce
    Seattle
    Brian, thanks for the info.
    Mike, I'm all good for bodywork and rotors.
    Best,
