View Poll Results: Do you have an oldwer Van Dieman still competing?
Voters
2. You may not vote on this poll
  • How well do you finish with your pre 1976 Van Dieman
    1 50.00%
  • How are you finding parts for your Pre '76 Van Dieman
    1 50.00%
Results 1 to 12 of 12
    Member spinmeister's Avatar
    Chalfont, PA
    For Trade Brake disc-1975 Van Dieman
    My rear brake discs are shot. I have an RF-75, but the origins and modifications over the years have murked up things. The OD is 9.100. The 4 bolt pattern is on a 3.406 BC(3 13/16 bolt circle) with 3/8 holes. The markings are as follows: 15E3 STANPART (this bit is a TAD foggy!!) 2L08304 MIN DISC THICKNESS .325 INS WITH .230 INS MIN THICKNESS OF PAD & BACK PLATE ASSY. The center thru hole is 2 5/8 DIA and the back offset is 3/4 inch. I have not been able to find replacements and I am running out of time for the new season. What are these. What small Britt car did these come from?? MG? Triumph???PLEASE HELP!!
    Contributing Member Comp89's Avatar
    Ottawa, Ontario. Canada
    Default Brake disc
    Check with http://www.universalracing.co.uk/
    Call them (it's best) 44(0)1953 789223 and ask for Simon or Ken. I bought some for my VD79 a while back and got great service.
    Did you check with http://www.campbellmotorsport.com/rotors.htm ? 906-863-5003
    J-Guy
    PORT ST LUCIE , FLA
    Default stanpart
    stanpart was the marking on many old triumph parts, ie spitfire. campbell motorsports, they advertise in the back of sports car , has located some odd disc for me in the past. and as suggested there is always simon at universal. who seems to know nearly everything that you will ever need to know.
    North Eastern NJ
    John:
    I got my SRD VD Rotors at Campbell, give him a ring...
    PH# 906-863-5003 - I believe that bet time to rech im is early eve, central time.
    Brown Deer, WI
    Liked: 48
    I have a standard 4x3.75" bolt pattern (triumph gt6) on my 75 Van Diemen. I'll double check when I feel like braving the cold garage. I'm guessing they are standard issue gt+6 or even spitfire part. I'll compare the rotors to the ones I have my 71 Spitfire.
    Mal from Australia might know of a source.
    Interested in seeing photos.
    Ian Lenhart
    lenhart06@yahoo.com
    Ian Lenhart
    Level 11 Creative
    www.level11creative.com
    lenhart06@yahoo.com
    Contributing Member Joe911's Avatar
    Gainesville FL
    My 1975 Titan used modified Triumph 2000 sedan rotors. I found several Triumph parts specialists in England by searching the WWW. Some of their web based catalogues were helpful and most returned e-mails. STANPART is Triumph.
    Tarpon Springs, Florida
    Liked: 25
    Have you tried to contact Primus Racing. They were THE VanDeimen gurus in the Southeast.
    http://www.primusracingparts.com
    Good luck.
    Ricky Bobby
    Contributing Member triumph_tech's Avatar
    Morrisville, Pa.
    Default Triumph Brake Rotors
    The Stanpart script makes it a Triumph rotor for sure. You need to re-check the bolt circle diameter, Triumph used two common lug patterns. The TR3- TR6 used a 4 x 4" pattern and the TR7-8, Spitfire, GT6 and Hearld used a 4 x 3 3/4" pattern. Most early FF's used Spitfire uprights, stub axles, and brake componets. Although the rotors may fit they are not the best choice for racing with today's brake pad compounds. As suggested in the earlier replies try Campbell Motorsports for real racing rotors, it is well worth a couple of extra bucks for the higher quality parts. I have sold Truimph parts for years and I wouldn't use stock Spitfire rotors on my formula car.
    Gary Valone #44
    Zink Z10-C
    Morrisville, Pa.
    Default Triumph Spitfire Brake Rotor
    John,
    I need to clairify my prior post with reguards to the bolt circle diameter of the Spitfire brake rotor. As shown in the photo, the hub with the wheel studs is mounted to brake disc with four bolts. The wheel studs don't mount on the rotor directly, but are part of the hub and thats why there is difference between the bolt circle of the wheel and the bolt circle of the rotor. The Spitfire rotor O.D. is 9.100" in dia., I don't have my parts books with me on vacation so I can't verify the other measurments. If you need more info or want to buy those rotors there is a guy that has a shop not too far away from your house that I'm sure can help. His shop's name is Triumph Rescue in Bally , Pa. 610-845-8217. Talk to Matt Bakes, he can take care of you. He is a dealer for several of the major Britishparts suppliers. www.triumphrescue.com
    If you want to call me direct, get ahold of Pat of A.J. for my cell phone number
    Gary Valone #44
    Zink Z10-C
    australia
    Default rear discs
    the discs are probably tirumph but ken at universal will know for sure
    my car didnt come with rear discs as it is a project car
    are you using inboard discs because if you are any brake shop shoud have something that can be drilled to fit next time I go to the shed I will talk to my mate to see what we are going to use
    Ian do you have any current photos?
    my car has stalled for a while whilst the fibreglasser get his act together
    spinmiester do you have any pics of you car?
    mal
    Chalfont, PA
    Default PIcs of car
    I have some of the offending brake parts and one of the car. The body is home made in the 80's by a previous owner. The discs bolt to the 12 hole item 15 in the Spares G List in the Hewland Mark 8/9 manual (inboard). It uses 6 bolts. I am a machinist and will drill the holes if need be. I want to know what they are, so I can replace them, or buy vented racing equivalents. Next year the fronts get done.
    australia
    Default disc brakes
    your car looks nothing like mine
    that part number and sizes are triumph 2000 sedan with the diameter machined down
    I would go to a good brake shop and ask them what they have as old triumph bits are hard to find and I would rather spend a bit more on good brakes
    mal
