Results 1 to 5 of 5
    Member vancourt's Avatar
    Michigan
    Default Dunlop Vintage Spec Tire Pressures
    What are good tire pressure settings front and rear for the Vintage Spec Dunlop Treaded tires?
    Senior Member Henrik's Avatar
    Sweden
    Liked: 17
    Default Preassures
    Hello
    You probably would like to have aprox 17-18PSI (1,3 Bar) hot
    They usally go up 1,5-3 PSI from cold to hot depending on driving style
    Henrik
    "Trying is the first step towards faliure"
    Homer Simpson
    www.hhtech.se
    Liked: 123
    Default Pressures
    I like to aim for 18 psi hot, but there is a range you can experiment with. Phil Lamont says 22 psi is the target number, he's Mr. Dunlop I find them skatey at that pressure, but I'm slow anyway.
    Lincoln NE
    Liked: 85
    on the Titan I wrench, we send him out at 12 front / 14 rear cold
    Charlie
    Denver
    Liked: 301
    14(f) - 16 (R)(hot) or baybe 16-18 (hot) depending on your comfort. I've been running 16-18 hot after doing some tire temp testing. Wear seems to say that's OK. Pretty even across the tire.
