    Pinetop, AZ
    Default Lola 342 master cylinders
    I recently purchased a Lola T342. The original master cylinders were .62 (5/8) for both front and rear brakes. They had been replaced with Wilwood master cylinders. .75 (3/4) for the front brakes and .62 (5/8) for the rear. A friend suggested that I should switch them around, putting the .62 (5/8) for the front bakes and the .75(3/4) for the rear.
    Any input on the pros and cons on this issue would be greatly appreciated.
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default Lola master cylinders
    Your friend is correct, swap them. Your vehicle probably had a master cylinder replaced since it was new, and that's when a 5/8" bore Lockheed was installed on the rear. A larger size for the rear brakes was common.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    Contributing Member Mike Jones's Avatar
    Kansas City
    That's how mine is set up. The 5/8 goes to the front.
    Mike
    Senior Member Scotty's Avatar
    Queen Creek, AZ
    Default Brakes?
    Hey Jared!
    You told me you never use your brakes!
    73 Lola T-340 #25
    Monty Python Addict "NEE!"
    SouthWest Formula Ford
    Pinetop, AZ
    Kea and Mike:
    Thanks for the input. I will make the switch.
    Scotty:
    Brakes, what brakes. The master cylinders are there just to get me thru tech.
    Senior Member SCOTTY81's Avatar
    PLANO
    Liked: 35
    Brakes are over rated..
    Scotty
    Scotty
    Est. 1990
    Taylor Race Engineering
    Contributing Member Mike Milner's Avatar
    Phoenix Az
    Liked: 6
    Default Listen to your friends
    The advice you have received so far is sound . However , brake systems are not ALL about the master cylinders .
    Before you switch stuff around make sure whoever put the small bore master on rear did not make other modifications as well . Like larger calipers on front ( typicaly LD20s) .
    The Hydraulic theory applied here is correct but will work for you only if the calipers are the same size front and rear and the rotors are all the same diameter .
    Make sure before you switch .
    If you have questions call me ...You know the number .
    Regards , A Friend .
