Results 1 to 15 of 15
    Derby Kansas
    Default lola t200-t202 brake rotors
    I Would Like To Know How Many Lola 200 / 202 Owners Would Buy New Brake Rotors At A Resanable Price Say 300.00 Dollars Per Rotor??
    If Enough People Would Show An Interest It Would Be Much Less Than The Cost Of Rotors From England
    Thank You For You Help
    Larry
    NJ
    I would think $100 per rotor would be more reasonable. Try Campbell Motorsports, I know he makes various rotors for Lols, Crossles, Reynards, etc., and all for around $100 per. If he dosen't have them off the self, he could probably make them. You can find his info on my web site www.TheLolaRegistry.com under "Parts Sources". Good luck, Allan
    Derby Kansas
    Default brake rotor
    allan
    i would agree that 100.00 would be ideal for a brake rotor
    have sent one of my rotors to larry campbell to take a look at
    his current blanks will not work so a new set of casting would be required
    still need to know how many could be sold and what price is reasonable
    the 300.00 was was a number i threw out to see if you would respond
    thanks larry
    Senior Member Dave Welsh's Avatar
    Ocala, FL
    Liked: 43
    SascoSports has a T200 and a T202. They might be interested.
    www.sascosports.com
    NW Colorado
    Liked: 30
    Default Lola Rotors
    You should take a look at John Bradley's (up in Evergreen) Lola rotors, that Truechoice put together years back. They turned an aluminum hat and the setup now uses flat disks bolted to the hat. I think the price for four was around $500. He whined then. Now all he has to do is replace the flat disk, which costs next to nothing.
    John Mihalich, Jr.
    Lotus 61/FF/28
    RMVR #61
    colorado
    Liked: 162
    Larry and John: Nikkel and JB did the Truechoice rotors about the same time, but my recollection is that the cost was closer to $1200 for four. $500 would be a steal, then or now.
    Derby Kansas
    Default Brake Rotors
    Bob I Have Been Waiting For Your Response
    Custom Made Hats And Disc Would Be About 1800 To 2000 Dollars
    English Rotors From Fowler And Goodwin About 2400.00 Us Dollars
    I Hope That There Could Be Enough Interest That Larry Campbell Can Make Up New Rotors At Aprice The Car Owners Will Pay And At Whitch Mr Campbell Will Make A Profit And Be Able To Continue Supply His Product To The Racing Community
    Larry Tapp
    NJ
    Default Lots of potential customers
    According to Lala Cars Ltd., there were about 120 Lola T200 series cars made. So, given a 25% loss over the years, there should be about 90 owners with the potential need for 360 rotors sooner or later. Not a bad number to run 100 piecies on spec. Larry, you out there?
    Menominee, MI 49858
    Liked: 88
    I'm out here Allen-- way out in the northern woods of Michigan's Upper Peninsula.
    I floated the question about doing some 200 series rotors back in late 2001- early 2002. There wasn't much interest then so I never went forward. There seems to be much more interest so I'll look at this rotor. I'm always interested in adding products to the line- if there is some market.
    I'm getting the sample and will work with the foundry I use to work out some numbers. Based on the latest foundry patterns I bought, I don't think I can make $100- but should be able to easily beat the $300.
    Larry Campbell
    Derby Kansas
    Default Rotor Sample
    The Sample Rotor Left My Shop By Ups On Friday To Campbell Motorsports
    Thanks To Everyone For The Interest
    Larry Tapp
    patterson ca
    Default lola rotors
    Larry, Any luck with rotors?
    Derby Kansas
    Default 200-202 rotors
    larry campbell is working on the project
    will post the results as soon as we know
    thank you
    larry tapp
    Cincinnati, Ohio
    Default Lola Rotors
    I had rotors and top hats manufactured about three years ago. Cost was in the neighborhood of $1,000. I borrowed one of Bob Darcey's rotor/top hat for a model and had them made as a two piece assembly. All the manufacturers I talked with said you can't buy billet steel in the size required to machine them as a one piece unit (and stay true to the original.)
    The guy I usde is out of business, but the two piece assembly's he did for me were very nice.
    Dan
    Derby Kansas
    Default Lola Rotors
    Larry Campbell Has Advised Me That At This Time The Making Of Cast Rotors For The Lola 200 Series Is Not Possable
    Contributing Member Tigaman's Avatar
    Virginia Intl Raceway
    Liked: 67
    I had Coleman do rears for my T-590 (which I think is similar) for less thn $200/each.
    -Peter
    -Peter Krause
    1984 Tiga SC
    www.peterkrause.net
    "The Driver is the Greatest Performance Variable in the Racing Equation"
