Page 11 of 11 FirstFirst ... 7891011
Results 401 to 426 of 426
  1. #401
    Ohio
    Liked: 6
    Default Gingerman Gears for Honda power
    Looking for recommended gears for Gingerman for FF with Honda power. Hoosier R60 22.7 diameter.
  2. #402
    Senior Member racersonly's Avatar
    Oshkosh,WI
    Liked: 95
    Default Gear ratio suggestion
    Formula Ford on Hoosier vintage tires for Blackhawk Farms?
    Jack Bartelt
    Lola T540 CFF
  3. #403
    Michigan
    Liked: 6
    Default Gearing for VIR needed
    Looking for gearing for VIR long course with a 10-31 rear axle.
  4. #404
    Muleshoe, Texas USA
    Liked: 160
    Default Barber Gearing?
    Deleted - no longer needed.
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
  5. #405
    Liked: 854
  6. #406
    Global Moderator Chris Robson's Avatar
    Hebron, CT
    Liked: 113
    Default Thompson
    Looking for gearing for Thompson with 10/31 R&P, Kent engine, Formula F Hoosier spec tires.
    Chris Robson
    Accelerated Performance Coaching
    http://APCDriving.com
  7. #407
    Muleshoe, Texas USA
    Liked: 160
    Default Homestead gearing?
    I am helping out a new driver in FF and would like to know current thinking on Homestead gearing. I found this one post from many years ago:
    Thanks in advance!
    Jay M
    10-31
    17-34
    20-31
    22-28
    25-27
    John
    RaceDog
    Messenger Racing
    Muleshoe, Texas USA
  8. #408
    Prescott Valley, AZ
    Liked: 64
    Default Minimum RPM?
    Curious as to what is the recommended minimum RPM for a Kent Engine?
  9. #409
    Liked: 1112
    Typically not much HP below around 4700, motor comes alive around 5200. However, some builds have enough low-end torque to let you pull from a little lower. YMMV.
  11. #410
    Ridgecrest, Ca
    Liked: 259
    Default Road America gearing for a 10:31 Kent
    I've looked, but after sifting through pages of info can't really find anything approaching definitive for a 10:31 Kent at Road America. would greatly appreciate local thoughts for an average/above average Kent; it's a bucket list question. track time would be much better spent learning the track versus working gearing........
    Art
    artesmith@earthlink.net
  12. #411
    Prescott, AZ
    Liked: 182
    Default Podium club, Casa Grande, Az
    Any suggestions, 9:31, CFF, Kent? Thanks!!
  13. #412
    New Jersey
    Liked: 39
    Default NHMS (New Hampshire Motor Speedway)
    Does any one have suggestions for a Club Ford on R60 Hoosier bias ply slicks for NHMS (New Hampshire Motor Speedway) road course?
    Final drive 9:31 for me, but I can do the math if only 10:31 suggestions are available.
  14. #413
    locust valley, ny USA
    Liked: 142
    looking for gearing suggestions for a Thomson, vintage FF, kent, treaded hoosier vintage tires, MK9 box so i believe 8/31 r&p
    thanks!
  15. #414
    Santa Ana
    Liked: 258
    9/31. I’m checking
  17. #415
    Contributing Member Andrew Stein's Avatar
    East Varick, NY
    Default Thompson gears
    Quote Originally Posted by HazelNut View Post
    thanks!
    9/31 for me is 19:32, 21:30, 23:28, 24:26
    equivalent for 8:31 is 20:30, 23:29, 24:26, 26:25
  19. #416
    Sydney, Australia
    Liked: 146
    Default 1/4 mile drag gearing
    For reasons I won’t bore you with, one of the two proper race tracks near Sydney is closed. So one of our local clubs is going to hold a championship round at the local drag strip. Any suggestions for gearing for a FF1600, with a 9:31 diff?
  20. #417
    Liked: 3286
    No gearing suggestions, but get some small diameter hard compound narrow tires so they will spin and not destroy your CV joints, clutch, etc.
  21. #418
    Sydney, Australia
    Liked: 146
    Dave, thanks for that, but in this part of the world, we have standing starts in all of our races, which normally involve reving to 6,000 and almost just drop the clutch. Its rare that you will light up the rear tyres or break anything, you just go.
  23. #419
    Phoenix, AZ
    Liked: 79
    Default Podium Club/Attessa Casa Grande, AZ
    For 10/31 and Hoosier FF tires, I've used 17/33, 17/28, 18/25, and 24/28. Those are not optimized for track direction.
    This month they are extending the curbing on most corners, using curb profiles and tractive paints that will allow the motorcycles to run on the curbs as part of their race lines. This will change the lines a bit and will increase the straight speeds a little. It will be interesting re-learning the track.
    The West-bound line onto the main straight is being extended past the top of the hill. That plus longer curbs on the right prior to the hill may make more difference than we think in straight line speed.
    YMMV
    Jim Edmonds
    Phoenix, AZ
  25. #420
    Liked: 854
    Hi Grahame,
    First off, I've never done this. Second, I'm probably just going to say what you were already thinking but wanting confirmation. Nevertheless, opinion follows...
    Most of the time is gained from the launch so probably the best gearing would be using lowest 1st gear, hopefully a fixed 1st gear.
    Then, assume you'll hit about 100 mph in 4th, which would be 22/29 for my Vintage tire on my March FF at 6800.
    Spacing 2nd and 3rd based on my gearing norms gives me this:
    14 36 RPM at shift:
    17 34 5289
    20 32 5440
    22 29 5602
  27. #421
    Liked: 802
    thanks!
    "MK9" doesn't necessarily mean an 8:31 by default.
    Pretty easy to check without pulling the side cover using the "how far do the tires roll for one rev of the flywheel" method and some simple math with a known gear ratio in the box.
    The difference between an 8;31 and 9;31 is 12%, so accuracy doesn't have to be crazy.
  29. #422
    New Jersey
    Liked: 39
    Default Pitt International Raceway
    Suggestions for Pitt International Raceway please. Thank you.
  30. #423
    Chatham Center, New York
    Liked: 862
    Umm... what kind of car, what dif ratio would be a good start.
  31. #424
    La bruyère Belgium
    I did this exceice a few years ago
    Regards
    Etienne
  32. #425
    Liked: 3286
    Default Gear calculation program
    I have an Excel spreadsheet that I likely got from ApexSpeed several years ago that makes the calculations easy for almost any combination. PM with your email address if you want it. You do need to have Excel on your computer to open it. This is what it looks like:
  34. #426
    Liked: 1112
    Default Spreadsheet
    I like this one, also from ApexSpeed some years ago.
