Results 1 to 8 of 8
Thread: Laguna Seca
    Helendale, CA.
    Post
    Any of you Northern Cal. guys have recomendations for gears. Using a 9:31 R&P
    I have 17:34, 20:32, 22:29, 24:27.
    Chris
    Chris Campbell
    West Coast
    Post
    I think you'll find 24:27 pretty tall for LS. FYI: Some quick guys run 24:28.
    Helendale, CA.
    Post
    We are running the Dunlops (Vintage) tires at 23" dia. Not sure what the slicks are I would suspect smaller.
    Chris
    Chris Campbell
    West Coast
    Post
    Actually our American Racer slicks are about the same as your Dunlops(C ~ 72.5" @ 14psi => ~ 23" D). Anyhow, if your Dunlops are "taller" than our slicks, you definitely want to run a "shorter" gear.
    Contributing Member Bill Kincaid's Avatar
    Palo Alto, CA
    Post
    I like an even shorter 4th than that (23:28). Between the very tight turn 11 onto the straight, and the climb up past start/finish, you just don't end up building up much speed by the time you get to turn 2.
    Member Bud Byrnes's Avatar
    Santa Monica, CA
    Post
    Chris, I have been trying to log on this is a test
    Bud Byrnes
    Santa Monica, CA
    310.625.9578
    andrew.byrnes3@verizon.net
    So.Cal.
    Liked: 29
    Post
    Bud:
    We hear you now....
    Senior Member Murray's Avatar
    Hemet ,California
    Post
    Wow, Jerry that must be a long wire. It took 21 days for Bud to reach you.
    Murray Chalmers Miss Lola's kept man.
