Hello all,
We have recently brought the Reynard 92H 009.
Would anyone out there have some knowledge of history or possibly photo's of it's previous life.
Regards
Carl Wall
the4walls@paradise.net.nz
Hello all,
Regards
Carl Wall
Any history or information about this car?
Formula Atlantic
Reynard 92H 009
Carl
Carl,
A little bit more info would probably help the flow of information. Who ran the car in the US? From whom did you buy the car? Somewhere I have inspection records of every Reynard I considered when I bought mine but haven't been able to lay my hands on it to reference the serial numbers.
Is this the Australian car that was on NZ Trade Me site a while back?
Hi,
Yes this was the car ex Australia.
I am awaiting paperwork in the post, hopefully this will give me more details.
I am trying to locate a set of front brake disc's, I can't seem to find them listed on AP or Alcon, The fronts are bigger in diameter than the rear disc's.
Measurements are:
6 bolt mount, 1/4 inch bolts, 139mm pitch:
O/D: 276mm
Width: 20mm vented disc
Any help would be appreciated.
They are the same as the mounting pattern on the rear just the bigger diameter. We have ours custom made.
Thanks for your help J Leonard can you give us a contact name to have these discs made or can you supply we require both left and right
colemanracing.com
colemantech@czo.net
Discs will be standard vented disc
are the callipers AP?
if so they will be an AP disc
i have some toyota engine adaptor plates for the 92 or 93 car
They are AP pattern just larger diameter and sometimes thinner. You are saying you have the casting that is the sump tank that goes between the Toyota and FT? Are they the early ones or the later updated version with extra gusseting?
I have just received the paperwork for this car, please see the attached images.
There was a letter included in the paperwork from Randy re spare parts available etc..., dated 2001 or 03 I think.
Small world!
Carl
I don't really want to be in the parts business but did you get your front rotors taken care of?
Re the brake rotors, yes we did purchase a front set from Coleman Racing, thank you very much for the contact!
They arrived and have been fitted and raced on, no problems at all.
