PFM Engine and Gearbox Servicing Questions
This is the first time changing the engine oil and gearbox oil. I’ve read the Star Race Cars manual but it’s confusing.
I suctioned out 4 quarts of engine oil from the pedestal with the two rubber lines going to it. Prior to suctioning I had 6” of oil in it.
I replaced the oil and it’s at 6 1/2 “ from the bottom of the case. I used a fiberglass rod and I know I hit the bottom. Is this correct?
Am I only pulling out about half of the engine oil capacity? Is that why it needs to be changed every 2 hours of runtime?
Now for the gearbox. Am I correct that there is no way to check the oil level in the gearbox? I just loosen the rear cover and let it drain, then put 2 1/2 qts.of 75w-90 into the 1 1/16” plug on top of the gearbox?
Really hoping you guys can advise me.
