: Lola T93-97/20 Indy Lights.Engine.Gearbox.Drivetrain.
LOLA INDY LIGHTS :T93-97/20
ENGINE. GEARBOX. COMPLETE DRIVETRAIN PACKAGE FOR SALE OR SEPARATELY.
Can be used for a wide range of conversion applications. Also available all engine related accessories. Alternator, Battery,Starter,Flywheel/Clutch assembly, Complete headers, Ron Davis custom aluminum radiators/ oil cooler,All oil/cooling system hard lines and fittings, PI dash instrument display with complete harness and sending units. Engine gearbox adaptors to chassis and all related mounting hardware.
*Indy Cars * Formula 3000/Holden * Formula One
(Reliable cost effective drivetrain for track day events, fraction of the cost of O.E drivetrain)
*Sports Prototypes *NASA Prototypes *IMSA Lites
*Radical Car Conversions *Mid Engine Kit Cars For Track Days
*Excellent Engine for Superformance Corvette Grand Sport, Custom Street Restomods.
Contact us for details regarding your specific project.
*** Video engine startup and run through gears ***
https://www.youtube.com/watch?v=IQ7RQfrnkcA
Engine: * Detuned for Indy Lights gearbox and final drive specs 350- 400 ft- lbs torque. 350- 370 h.p @ 3500-4700 rpm.@ the wheel (dynojet)
Will produce over 500 h.p for Indy Car and other higher rated gearbox and final drive applications
Complete Chevy Dry Sump Engine,pump,pan. $7,595.00. Custom Ed Pink water pump,pulley,belt assembly $1,395.00. Hilborn,intake manifold,velocity stacks,air filter assembly,linkage,with fuel rail/ regulator /injectors $4,950.00.Haltech Elite engine ecu with Haltech Platinum WB1 with complete custom wiring harness, $3,988.00. Complete MSD distributor Ignition system $985.00.
*The Haltech CAN Wideband Controller is a plug and play product which increases the functionality of the Haltech ECU by using the Haltech CAN system which is available to all Elite and Platinum Series ECU's. It allows the user to accurately measure air/fuel ratios over a wide range from rich to lean via the Haltech CAN system for precise engine tuning.
(COMPLETE ENGINE FOR SALE : $15,950.00 * Includes Shipping In Continental U.S)
* Not included in listed price. Flywheel,clutch assembly, starter, alternator, headers.new battery,Ron Davis custom radiators,oil cooler, all engine,oil,cooling system hard lines,hoses fittings. Engine chassis,gearbox,adaptors. PI Dash display with complete harness,sending units.
(COMPLETE ENGINE ANCILLARY PARTS : $6,550.00 * Includes Shipping In Continental U.S)
*AVAILABLE FOR SALE SEPARATELY. COMPLETE GEARBOX-SPARE GEARBOX RELATED PARTS.
GEARBOX: Can easily handle 460+ h.p 395+ ft lbs torque. Also custom suspension a/arms of your choice can be designed utilising rear suspension pickup point mounts on trans case, including modern rear rocker push rod suspension configuration.
* EXCELLENT FOR FORMULA OR SPORT PROTOTYPE CONVERSION PROJECTS.
LOLA / T93-97 GEARBOX: with integrated engine dry sump oil tank. All rear suspension hardpoint pickup mounts. Clutch annular slave release bearing assembly, with gear ratios in box asis.
* SPARE GEARBOX RELATED ITEMS.
Extensive amount of new,good used gear ratios (180 sets) torque biasing diff,drive flanges, bearing carriers.
(COMPLETE GEARBOX AND SPARES : $12,950.00 * Includes Shipping In Continental U.S)
FOR COMPLETE PHOTOS GO TO LINK BELOW.
https://aandbpde.com/street%26track-sales
FOR DETAILS CALL : (805) 859-9374
https://aandbpde.com/race-cars
