4 Attachment(s)
Help w/ installation of a zeitler water/oil pump ass'y
I have a SUPER VEE 1600cc Zeitler water-cooled engine I am working on. I need input on the water pump/oil pump design he used. It is a combo package w/the water pump in the middle and I am try into find any photos I can of how the output of the water pump connects to the input port on the block. I also need the actual piece that accomplishes that. ANY help would be appreciated.
I just added photos. Keep in mind that the dry sump pan has two outlet line, one at each end. That tells me that pump sections 1 and 2 (from the front) are for those two lines and they send the oil to the oil tank (or filter and then tank).
The last pump section looks much "deeper" so I believe that it is probably the one that pulls from the tank and feeds the engine.
If there is anyone out there that has had any experience with these and can confirm/deny my assumptions, please do!
Lee
