I need a 90 degree fuel inlet fitting for FV carb. Not sure of the thread size to look for one. Anybody know where to buy one?
Garry
Garry
Gary:
If it is a stock 28pci threaded top, then the stock fittings and pipe can be bent to just about any shape.
Have several lengths in stock including new copper tubing
Dietmar
www.quixoteracing.com
If you have the space make the bend with steel brake line.... no copper.
If you do not have the space, then you have to fab something using silver solder. For clocking purposes it is nice to retain the stuck compression system soldered into a small steel block. come out of the block with whatever you like.
