DP04 Motorcycle rear sub frame Van Diemen
Hi,
I am converting a FE chassis to run in the P2 class with motorcycle power. I have purchased a rear sub frame assembly that holds a 1L motorcycle engine that I think might have been used in what Elan called the DP04. I believe that there were a couple of these setups that ran in F1000. One of which was owned by Ben Cooper at one time.
I am in desperate need of any pictures that someone might have that shows how the engine is mounted, in particular the front upper motor mounts, and some of the additional bracing within the engine bay. There are many bosses welded to the rear subframe in various locations and I have no idea what they are for. Additionally I could use some rear wing mount pictures, rear suspension pictures, and basically anything from the main roll hoop rearward.
Scott
