Recommendations on/pics of throttle cable hookup? '08 GSXR10
Hey all, hoping some can give some good examples of how best to attach a race throttle cable to the GSXR; my install has failed, and I'm having to rethink it.
I had obtained a good custom cable build with a 5.8mm lug that fit perfectly into the stock GSXR throttle cam, with the normal custom race cable build and 10-32 ferrule on the pedal end for the usual rod end hookup. So I was able to integrate it with minimal effort into the throttle body.
But I melted it (after bodywork changes), must replace, and those 5.8mm ferrule ends are no longer available. https://groups.tapatalk-cdn.com/smil...097-smiley.gif
So my throttle cable source (Averill) recommends converting to an install that will fit the normal 10-32 cable ends (so needing to adapt this to the throttle cam). I can think of a number of ways to accomplish this, but hoping someone will have or can take some pics of their preferred method?
I'm also considering flipping the cable, so it doesn't go up by my airbox - it's the heat rising off the header that's cooked it, no real shock. I can mitigate the heat, but all the better if I don't even put the cable in a risky area...
