6 Attachment(s)
Novakar J9 F600
1999 Novakar J-9 with J-10 updates
2006 Suzuki gsxr 600
Piontek billet oil pan
Piontek paddle shifter kit
2" axle and all peices
dual Wilwood dynalite calipers on front
Single Wilwood dyna light 4 piston on rear
Dual Speedway oil coolers piped in series (makes for very large surface area.
Braided oil lines
SXS oil filter block off plate with -8AN connectors (eliminates need for getting into gallery plugs on end)
Shoenfeld 4-2-1 exhaust that is in multiple segments so that you can install/disassemble without removing or tilting motor
Brand new Fuelsafe fuel cell, not fully installed
Holley Hydramat ( this eliminates the need for a high-low pump set up. that thing sucks fuel if just touching it - video of Hydramat
Aeromotive fuel pressure regulator
All fuel lines -6AN push type
Hyper racing mod wiring harness
modded stock air box - i was able to mod the box, rotate 180 to keep low profile and maintain most of the volumn. modified top and used foam filter material
Pi system 2 dash with most needed sensors
oil pressure and water temp sensors installed
have oil temp, 2 rev boxes if decide to use coil pack connection for tach
speed sensor - not installed
plunge sensor - was used for rotation
beacon sensor, beacon, and tri pod
Spares:
complete spare body
a couple of sprockets, 39, 40, 15
various length rods with spherical bearings
2 brass radiators
front control arm
front hub that needs a little clean up
front rotor
rear rotor
and some other misc.
Not selling as race ready. Motor ran fine before getting new cell, old one had rot around fill neck but i still have it.
I have been messing with this car off and on for a few years and just doesnt seem to be. Someone else should enjoy it.
$9500 obo. - $9000 if before 08/26 as i am moving. This should be a super smoking deal to someone
C.Scott Chesser
ph - 8three2 8onetwo 52six4,
text or call, if call please leave VM and i will call back.
http://www.apexspeed.com/forums/atta...id=79993&stc=1http://www.apexspeed.com/forums/atta...id=79992&stc=1http://www.apexspeed.com/forums/atta...id=79994&stc=1http://www.apexspeed.com/forums/atta...id=79995&stc=1http://www.apexspeed.com/forums/atta...id=79996&stc=1
I think this is sold
If you bought this car, please drop me a line...
PM Sent
I highly doubt it but is this car still available?
