Anyoneknow where to find a specific steering rack boot
1 1/4 at the big end and 1/2 at the small end over 4 1/2 long
tricky part is i need a small OD 2" max
tried all the local suppliers but everything is so darn big in OD
When I needed a boot for my Tiga, I spent some time searching EBAY and ended up finding something that worked great. I bought 2 extra so I will never need them :ha:
john f
I bought a boot from McMaster Carr, cut it to length, and fasten the ends with Ty-wraps.
Dorman Products has a few rack boots that are cut to fit. Possible number is
614-020 . Most larger real Auto Parts stores should have.
I suspect any off-road parts shop will have shock boots or steering damper boots that will fit your needs. Probably will be longer than you need, but you can always cut them down.
second for McMasterCarr......
I found a universal CV joint boot at my local spare parts shop worked fine. Only a couple of dollars and it came with a range of diameters at both ends. Just cut to fit.
