Doughnut installation (overcompressed?)
After seeing someones driveshaft bouncing down the back straight during my last race, I'm replacing the doughnuts and adding do-nut savers.
The new doughnuts appear to be "over compressed" by the metal band, the doughnut bolt circle is smaller than half shaft and output flange bolt circle. Is this common?
I'm almost tempted to cut the band and put on a metal hose clamp, but wanted to ask you guys first.
I've also got a bent "ear" on the right drive shaft, looks like this car had a doughnut failure in the past. Any suggestions on repair or should I replace the drive shaft.
Thanks!
Angus
