1997 Van Diemen RF97 Widetrack
https://drive.google.com/file/d/1kOZ...usp=drive_link
SOLD
It's time to sell my car as I move to my next one. A lot of work has been done under my ownership to get it into the best mechanical condition it's been in for a long, long time. It runs and drives great, whoever buys it will have a great car to race!
Edit: I am 6'1 and about 180 lbs and fit perfectly comfortable in the car. It does have an extended roll hoop to allow much taller drivers to fit, the shift knob has been extended forwards, and it seems to have a widened cockpit, compared to other 1997s I've sat in.
The car is race ready! I just raced it this weekend, 7-22-23.
I'm having trouble uploading pictures, the set is available here, listed individually below: https://imgur.com/a/J66BAD0
https://imgur.com/OusYFIB
https://imgur.com/ocqiuk0
https://imgur.com/LbUifTU
https://imgur.com/NRcyMKE
https://imgur.com/CsjcYXU
https://imgur.com/0Pi4TcJ
https://imgur.com/PppRpXN
https://imgur.com/1z0XRwQ
https://imgur.com/hsFgteN
https://imgur.com/CXMhOhq
https://imgur.com/U7MMCHx
Highlights:
- Engine rebuilt by Cricket Farm Motors for 2022 season
- Shocks rebuilt June 2022
- New Starter July 2023
- New Clutch 2022
- New Fire System March 2023
- Widetrack suspension
- Pennon Raised Nose
- Pennon Diffuser
- Averill Front Wing
- Long Rear Wing Mounts
- AiM MXS data logger w/sensors
- GPS08 Module
- Smartycam HD GP 2.1 w/custom mount
- Belts good through 2028
- New front pads with one 10 lap race on them
- 8 gearsets included
What the car has:
- Widetrack suspension (converted in early 2000s)
- AiM MXS TFT color data logger
- GPS08 Module
- AiM sensors including oil pressure, oil temp, water temp, throttle position sensor, brake pressure, steering angle sensor
- Racing Radio and cable
- OMP Flat-Bottom Cut-Off Top Steering Wheel, Suede, 250mm with custom command push-buttons including thumb activated push-to-talk push-button on steering wheel
- Pennon Diffuser
- Penske Shocks (8760 Series) triple adjustable (rebuilt June 2022)
- Tilton hydraulic throw-out bearing 38mm (rebuilt June 2023)
- Tilton 5.5" clutch new 2022
- Quick disconnect oil, brake and clutch lines
- New fuel cell December 2018
- New TDC oil pump 2018
- Racequip belts good until 2028
- Pertronix Igniter II electronic ignition
- Pertronix Flame Thrower II Epoxy Filled Ignition Coil
- SPA Firesense+ fire system
- LD20 brakes all corners
- ICP calipers
What it comes with:
- Two sets of wheels
- One set Oz Racing with Hooser Spec Slicks
- One set Jongbloed with Avon Slicks
- Rain tires (unmounted)
- Multiple spare body panels
- Left and right side panels
- Right side pod upper and lower
- New engine cover
- Used engine cover
- Rear Nose Cover
- Spare Suspension control arms
- FR lower control arm
- RL lower control arm
- Multiple pushrods
- RR upper control arm
- Gearsets
- 17/33
- 18/32
- 19/32
- 21/30
- 21/31
- 23/24
- 23/28
- 24/26
- Custom oil dipstick and fuel dipstick
- Jumper battery / connector cable
- Two spare radiators
- Left and right radiator shrouds
- 5.5 qts oil
- 36 Weber carb
- 2 new rotors
- Spare brake bias adjuster
- 3 additional anti roll bars
- Spare starter (needs rebuilt)
- Dynomax muffler
- Supertrap muffler
- Wheel bearings
- Various filters
- A good amount of other miscellaneous spares and components
- Various reference material
What it needs:
- The bodywork is in ok condition and could use some loving
Price - SOLD
