Thoughts on disabling/eliminating
Side stand switch
Tip over sensor
Excva
Will
Side stand switch
Tip over sensor
Excva
Will
Here was my cheat sheet for the engine harness stuff. bottom is how to wire up the stuff for the starting and running. center section describes the different sensors. I didn't have the EXCVA on there for some reason but i think i just disconnected it and pulled one of the wires from the ecu plug.
basic things are:
clutch switch needs relay during start or you will be stuck in safe mode
side stand switch short
tip over needs a resistor as described below
ignition switch needs a resistor to simulate the key being in circuit
http://www.minibuggy.net/forum/contr...tml#post158256
https://www.apexspeed.com/forums/att...id=85483&stc=1
Very helpful.
Thank You
Will
