The water pump pulley on the crank seems to stick out too far. It is rubbing on the coolant tube.
I looked at pegasus and don't see the right combo. I also don't see how to remove the pulley on the water pump.
Hopefully I don't have to replace the water pump.
Also, does the upper coolant tube need to have a rolled end to hold the hose on?
It seems to be an engine mount + coolant tube.
